Ana içeriğe geç
Originally released in 2006, the NeatDesk is a desktop document scanner with ADF and full-duplex features. The early revision has model number "ADF-070108" and the newer revision is model "ND-1000."
36 Soru Tümünü görüntüle
My scanner does not respond when paper is inserted.
My scanner powers up but does not respond when paper is inserted. What's the problem and how do I fix it? Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Make sure paper is aligned properly. The rolls should turn trying to feed paper when you click on scan. If they are not rolling make sure communication is active between computer and scanner.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Great answer - thanks!
tarafından
Yorum Ekle
The board in the door needs replaced or the plastic fingers are broke
Puan 1
Yorum Ekle
My scanner's lights are green at first when I try to scan. It makes a buzzing noise but the paper does not move. Then the lights start flashing red. It appears there is communication, but the scanner is malfunctioning. What do I try from here?
Puan 0
Yorum Ekle
Yanıtını ekle
Bobby D sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,990
