iPhone 5c showing "no Service"
Hello,
My Iphone 5c does not connect to the provider. It is searching and saying „No Signal“. Some facts:
1. Wifi is working fine
2. GPS is working fine
3. IOS is 9.0.2. Update was succesful
4. Provider update was successful
5. IMEI is fine
6. Date/ Time is fine
7. My provider is detected, but on selection still no service
8. The sim works in another IPhone
What I did so far:
1. Reboot
2. Restore from IPhone
3. IOS Update from 8.4.1
Could it be:
1. A loose antenna?
2. A defect chip (which one?)
3. The Sim connection to the Iphone?
Any Ideas? Anything you can exclude?
Update (10/08/2015)
Also some more tests:
The hidden App "Field Test" Just shows connecting. With my other working IPhone 5c I get into the menue.
With my second Iphone I got inside 3 points and outside 5 points signal strenght, also it shows inside 4 carriers. The broken one of course no signal, but shows inside only one carrier and outside 2 and sometimes 4. But again without connection.
So for me it could be the antenna, correct?
Update (10/10/2015)
I guess it is brocken now.
I put out the connector next to the battery first. Now:
No Charging,
No Home Button
No Itunes connection.
Any Idea?
Bu iyi bir soru mu?
3 Yorum
Hello Jamie
that's what I did as well. Did not work. I guess it is more hardware related
Machen tarafından
Forgot to say that my signal strenght on the working IPhone is -80db outside.
Who is interested in the Field Test App:
Dial *3001#12345#* and hit the tab Button.
Hold down the Sleep/Turn Off button until the Slide to power off screen comes up. Now, instead of turning the phone off, release the Sleep/Turn Off button and hold the Home button for a couple of seconds until it will return you to the Home Screen.
You can tap on Signal to switch between the numeric and dots display.
Machen tarafından
I hope you didn't use metal tools to remove the battery connector
iMedic tarafından
