Why doesn't my computer start up when I push the power button?
I charged my laptop with the same power adapter that came with my laptop, but I am still having troubles turning it on.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You may want to reseat the power button cable. Remove the screws on the bottom with a PH0 screwdriver, then use a flathead screwdriver to pry off the upper and lower case. Use a spudger to remove and reseat the ribbon cable that connects the power button.
Bu yanıt yardımcı oldu mu?
You may have a faulty battery. This could be due to either a hardware or software problem. You can find out by flashing your BIOS. Follow the instructions to update your BIOS. After your computer has restarted test and see if you updated laptop will power on without being plugged in. If not, you may need to purchase a new battery and install in
either the power switch is bad or the battery is not charged and the power supply is bad
wbw
I have dealt with many models of the HP DV4-xxxxxx. When you plug the power adapter into the Laptop you should see a little white led light to the left of the power port where the adapter is. With a battery installed or not this light should be on if the Motherboard is accepting power. If your battery is good you will also see a led light on the left front of the Laptop indicating it is plugged in and charging. If your battery is completely dead but will still take a charge the light will be blinking. It will blink until the battery starts charging and then become steady. If it keeps blinking the battery is bag and will take a charge. Replace the battery or you can remove it and operate the Laptop with just the power adapter. I will post more about this No Boot later.
Sorry, the part about if the "battery light keeps blinking" the battery is bad and will "NOT" take a charge.
The LED light by the power adapter is on. Hard disc starts to spin, and then stops. White lights are blinking next to the Caps Lock button on the left and Scroll light on top row. ???
I too have dealt with a few HP dv4 S if the Caps light light and the scroll light light are blinking it's an indication that you either have a motherboard or CPU failure.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 681
Does the machine show any lights when plugged in does it do anything at all when you try to start it . are there any post beeps
Jimfixer tarafından
none that I can find
W B Whisenant Jr tarafından
