Ana içeriğe geç
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98 Soru Tümünü görüntüle
Keurig K40 not brewing
Heats up, cup lights flash, press any cup size, hear rotating noise and then nothing. Couple minutes later all three lights come on.
Bu iyi bir soru mu?
Puan 4
7 Yorum
I have a Keurig it runs the water through but as soon as I put a cup in it won't work
tarafından
Un plug it, take the water tank off, clean the piercing needle in the top with a straightened paper clip being inserted into it. If that doesn't work; try "burping" it like I did by lifting up on the handle, putting it front side down in the kitchen sink and taking off the bottom....it will do a power flush of the system.
tarafından
I cleaned the screen at the bottom of the water tank with a new unused toothbrush and my machine works like new again!!!
tarafından
This is a common problem with the Keurig if it has been sitting unused for several months. The pump can't prime because air has entered the line. Remove the water filter from reservoir, fill the reservoir half full , plug the unit in, and power up. Hold the reservoir unit and rapidly lift/lower the reservoir until you see bubbles emerge from the suction area. When the bubble stop, the line is cleared and the pump will now prime. This is also a good time to change out the water filter and to a cleaning and descaling
tarafından
Thank you!! I followed your instructions step by step and it worked. I'm back in business I'm about to have a Cinnamon Dolce!!
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Harry Gray, could be caused by a clogged line or valve. Clean the valves and the line by using this guide
Bu yanıt yardımcı oldu mu?
Puan 5
5 Yorum:
While this detailed instruction is appreciated, a WARNING would be it is difficult to reassemble some of these parts, particularly rescrewing the reservoir filter and realigning and rescrewing the top covering. Also, this fix does not address the "machine gun" sound our K40 makes.
tarafından
Worked like a CHARM!!!
tarafından
still works if you do all the steps!!
tarafından
Didn't work. Any other suggestions?
tarafından
@kalamity what you got going on? Give us more details.....
tarafından
Yorum Ekle
The burping worked with the first cup but then the next cup went back to not brewing. I ended up taking the carbon filter out permanently, reburping again and now it works fine.
Puan 0
Yorum Ekle
Yanıtını ekle
Harry Gray sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 27
Son 30 gün: 95
Her zaman: 42,836
