Ana içeriğe geç
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Soru Tümünü görüntüle
Won't turn off running on on battery (Não desliga só com bateria)
Won't turn off running on on battery.
I press the power 1..2s and nothing
If I plug in the power then pressing 1s the power button turns the console off.
When is running with the power cable inserted (and connected to an outlet) disconnecting the power cable turns the console off.
The battery only charges half way.
Different battery... Same problem.
Different Power board... Same problem.
Não desliga só com a bateria.
Carrego 1..2s no botão de power e nada.
Se ligar o carregador, carrego 1s no botão de power e desliga
(o carregador tem que estar ligado à corrente)
Se estiver com o carregador ligado e se desligar o carregador da corrente ou se retirar o cabo da consola, ela desliga-se.
A Bateria parece não carregar totalmente... (retestando)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
There is only one answer to this problem and it involves buying a new battery and a new charger. sorry
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I have 3 chargers and 3 batteries.
The problem does not seem to reside with them.
The batterie charges to a full in other nintendo with the same charger.
But thanks.
tarafından
i am sorry that i could not help
tarafından
Yorum Ekle
Same problem here. Could you find an answer please?
Puan 0
Yorum Ekle
Yanıtını ekle
Luis Ramalho sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 74
