Ana içeriğe geç
Lehimleme, iki metal parçasını birbirine bağlamak için kullanılan bir yöntemdir aralarında başka bir dolgu metalini eritmek. Birçok çeşit var ancak bu makale size lehimlemenin temellerini öğretmek için tasarlanmıştır. elektrik lehimlem
56 Soru Tümünü görüntüle
hot air soldering station
Can you suggest me a good hot air soldering station included iron solder to work with smd components?
What do you think about it?
http://www.amazon.it/STAZIONE-SALDATURA-...
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
castericca, for as long as it works for your purpose it is a good station. It depends on what your plans are. If you are going to do a lot of soldering etc. try to look into a HAKKO or Weller if you are going pro. If it is for the occasional repair, the one you are looking at will work. Biggest issue with the less expensive ones is the differences in temperature control. Some are all over the map with that and some are closer. You can always use a thermometer and thermocoupler to control your heat better. Remember that any tool that works for you, is the right tool.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
my work is for the occasional repair. I'd like to buy Hakko to learn micro soldering but cost is very high
tarafından
Yorum Ekle
Looks sweet. But, Jessa Bethany told me not to buy a combo...
Puan 1
3 Yorum:
Do you have experience in microsoldring? What equipment are you using ?
tarafından
Very little. I'm using a 15 watt soldering iron manufactured by radio shack. Looking to get a hakko brand soldering station and unsure about which microscope. Also I'm seriously underpaid. So I'm not just running around buying what I like
tarafından
I agree you, Hakko is very expensive system.
tarafından
Yorum Ekle
Yanıtını ekle
Riccardo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,123
