Ana içeriğe geç
The LeapPad Ultra is an education based tablet developed for kids of the ages 4-9. It was released Summer 2013 with an MSRP of $99.
8 Soru Tümünü görüntüle
My LeapPad isn't charging, why?
Even when I plug the charger into the LeapPad it still doesn't charge, what's wrong?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This issue could be a damaged battery or a damaged charging port. Try to switch out your battery with another one to verify the issue. To do this, check out our Battery Replacement Guide. If the LeapPad still isn't charging properly, then you will have to replace the Charging Port.
Bu yanıt yardımcı oldu mu?
Puan 9
4 Yorum:
Where would you find the battery replacement guide? My leappad 2 is not charging at all as well. I have it on the usb pord, there is no charging light coming on but when I press the power button to try and turn it on, it will just blink green once and still stay off. What does this mean?
tarafından
All guides are in process and in private at the moment. The battery replacement guide will be posted to the public very shortly.
tarafından
Please refer to our new device page for any questions. LeapFrog LeapPad Ultra
tarafından
Hi, I have this same exact problem. What did you do to fix it? @KAITLYN FITZGERALD
tarafından
Yorum Ekle
Bu cevap aslında başka bir soru için verilmişti.
I actually solved this on the leappad epic. Remove the 6 screws from the rear cover and 1 screw by the stylus. Remove the battery, hold down the power button to discharge and remaining power for 35 seconds. Reinstalled the battery charges just fine now.
Puan 6
11 Yorum:
removing the battery and holding down the power button for 35 seconds and then puting the battery back in worked thankyou our childs tablet has been dead for weeks she is so happy it works again
tarafından
Glad it worked it happened 2 our daughter 1 day out of warranty. Its been fine since i posted this. Left out the battery removal tip. There is 2 pieces of double sided sticky tape under it. They stick slightly out and can be removed like 3m command strips. Then the battery comes out. Works just fine without them when you put the battery back in.
tarafından
Do I unplug the battery jack as well to perform this discharge??
tarafından
Thank you, thank you, thank you! Our epics have a lot of my kids schooling apps on them. I didn't have to remove the battery. I only had to disconnect the wire running from the battery to the tablet. Now it is charging like a champ. Thank you again!
tarafından
I tried this advice and it worked the first time. (Thank you!) A few months later, it stopped charging again. I followed the same advice, but this time also removed the wire, but it's still not charging. Please help!
tarafından
6 tane daha yorum göster
Yorum Ekle
our leapfrog epic tablet stays on 1% , even if its on the charger all night , it just stays on 1% , its like it is infact fully charged but isnt saying any other percentage other than 1.
Puan 1
3 Yorum:
Same with my Kid's LeapPad3. It keeps charging only 1% even when the battery indicator shows Green Light. Its not even to 3 months they started using it.
Thanks
tarafından
I actually solves this on the leappad epic. Removes the 6 screws from the rear cover and 1 screw by the stylus. Removed the battery, held down the power button to discharge and remaining power for 35 seconds. Reinstalled the battery charges just fine now.
tarafından
my child leap start will not charge it only came with batteries when I bought it but has an outlet for a charger. Someone please help me get this thing to working.
tarafından
Yorum Ekle
I my son just recieved it for xmas. And it just stopped eorking i tried the removal snd its back on. I thought i had to replace the whole item. If i had to would i be able to transfer the apps i purchase on to another ?
Thank you
Puan 0
1 Yorum:
It worked thanks 👍
tarafından
Yorum Ekle
Yanıtını ekle
Chad Wilder sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 4,799
