Ana içeriğe geç
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Soru Tümünü görüntüle
Soru Kapandı
Will not take a charge
Hello,
I have a Macbook Air that is not charging.
When you connect a power cord, The computer lights ups and shows that it is connected to power on the battery indicator. Also the light on the magsafe connector is always green.
I have tried the following:
Replaced power cord
Replaced battery
Reset SMC a number of times
Replace the I/O board
Heating the brick up with a hair dryer
Sitting on the brick to heat it up (hate to admit it!)
The behavior has not changed. See my Coconutbattery screenshot .. one with cable connected and one not connected.
Coconut Battery Cable unplugged
http://imgur.com/nulDQ7s
Coconut Battery Cable plugged in
http://imgur.com/kTSBIoz
Any help or suggestions would be appreciated.
Regards,
John
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi John
I presume you checked all of this points: http://www.macworld.co.uk/how-to/mac/fix...
And with all the repairs you already tried, last thing coming to my mind is the magSafe itself. Check not only for debris, but also check if the contact pins are clean on both the mac and the charger.
http://osxdaily.com/2014/02/04/magsafe-w...
Good Luck
Norbert
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 93
