Ana içeriğe geç
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
49 Soru Tümünü görüntüle
Why isn't my home button working?
I have to repeatedly press the touchpad in order to get the home button to work. For the rare times that it does work, it's very slow to respond. How can I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Open up and make sure the bottom 2 center ribbon connection and the top usb cable connection are all intact. Once that is done, restart phone and try.
If it is ok, proceed to cover back phone
Hope this helps
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The OnePlus2 has had reported grounding error issues causing this to happen. Sometimes something as simple as holding the phone at a slightly different angle when you use the home button can fix the problem. Another thing that you can do to fix the problem is go into setting and enable "On Screen Navigation" which allows you to use a home button on the screen.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
Kayla Williams sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 729
