Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazı tamir ederken daha önceki modellerde kullanılan aynı tornavida ve plastik açma araçları gereklidir. GSM/CDMA olarak, 16,32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renkli modelleri mevcuttur.
3922 Soru Tümünü görüntüle
Can I reattach a severed Home button FLEX CABLE?
I inadvertently broke the flex cable of my home button while lifting up the screen.
I read that a replacement home button will NOT allow me to use Touch ID anymore.
Is it possible to repair, maybe solder the flex cable that I broke?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
It is impossible sadly. They are directly correlated with the logic board for security reasons and if you break one you're out of luck. You could try and find a new logic board with a home button but that might be costly.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
It is possible, I've seen people do it.
Puan 0
Yorum Ekle
Got the exact same problem, two different answers...
@Rocket Repair: so basically the cable itself is linked with the logic board and not the Touch ID sensor? That means hypothetically you could change the home button if you keep the original cable?
Puan 0
Yorum Ekle
If it's just a broken flex cable then with a lot of patience they can be bridged with fine wire. It was done on a camcorder so maybe similar, see this video
https://youtu.be/FzqIoq8LEEc
Puan 0
Yorum Ekle
Yanıtını ekle
Alex222 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 223
