Ana içeriğe geç
Repair guides and support for cars, trucks, and SUVs manufactured by GMC.
235 Soru Tümünü görüntüle
oil leak towards front of engine
recently had oil change, going down road stop to fuel up check oil,to notice 2 qts. low, oil cap is tight,oil filter is tight, front of engineand all of under carrage is fuul of oil,only lower half of front of engine covered in clean oil...???
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorumlar:
had a repair shop lift an observre my oil leak problem,they responded; to much oil on engine to see where it had come from,,possibility from front seal....
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Get a couple cans of engine degreaser and follow the directions to remove the oil from the engine (make sure you are parked somewhere that wont stain)! Refill the oil and start the engine while monitoring where it leaks from.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
timothymanie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 240
