Why is my password not working only flashing the light
my password not working only flashing the light why
my id is SAADBAIG267@GMAIL.COM
FB NAME :SAADBAIG
Bu iyi bir soru mu?
FB NAME :SAADBAIG
Bu iyi bir soru mu?
my password not working only flashing the light why. and my windows is hang
Bu yanıt yardımcı oldu mu?
Same problem here!!!
Windows 7 stop working.
In my case it look like it's the UBS adapter is not ok...
I move the cable and the light comeback, and some time the "Disk Management tool" can see my HDD, but can't initialize it.
You need WD Smartware. When Passport asks for password put in the wrong password 5 times it will then ask if you want it formatted say yes. Then it will work fine. You will lose all info on the disk but have functioning disk.
what if i dont want to loose the info on the disk is there a recovery option?
I want PassPort to answer the question. That's why I'm here.
My passport WD was blinking and beeping. Now it's only blinking. Hasn't happened before. Truth is I barely ever use my computer anymore. After almost 30 years I'm almost totally out of Microsoft but I have lots of files & pictures there I'd prefer not losing.
i have similar issue here, the light to my passport is on but cant read the device? is it a cable issue?
Hi, Have you tried a different cable? Have you tried a different USB port? Have you even tried a different PC? What have you tried?
Same Problem
I have the same problem too. Took it to an Apple store and was told that the HD is broken. I do not want to spend hundreds or a thousand to get all my files off so I can put it in my new drive. Help!
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 9,982
