Replace connector on motherboard of Fairchild Channel F
I have a Fairchild Channel F that I bought, where I had to replace the onboard speaker. I did this with no problem, but when I went to re-assemble the unit, one of the connectors for the ribbon cable came off of the motherboard. The ribbon cables are housed within the cartridge assembly, and they connect to the motherboard through a 10 pin connector directly, meaning there is no male connector on the ribbon cable. It's a flat 10 pin cable that pushes directly into the connector on the board. What I'd like to do is either a) replace the connector with a new one, or b) make the ribbon cable connection a true male/female connection. Here is an image of the motherboard. The connectors in question, are directly under the box shield on the right (there a 2 connectors side by side).
I'm not too familiar with ribbon cables, or soldering onto the motherboard for that matter, but I can get assistance with that. I just need assistance on identifying the type of connector that I need. Thank you.
Bu iyi bir soru mu?
