How do I install MyDrive Connect on my computer?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
These simple steps should help you with your problem :
1. Follow this link to get started
2. Select your country of origin
3. click "get started" on the following page
4. Select "Download MyDrive Connect" on the next page (if you are using a mac, select the link below that!).
5. Run your downloaded program
6. Accept the licensing agreement
7. Click install to install MyDrive Connect
8. Congratulations, once you plug in your device you should be able to connect it with MyDrive Connect!
Bu yanıt yardımcı oldu mu?
I've tried the MydriveConnect it just keeps spinning and resetting. TomTom had a repair zip drive in the past that would correct bad software. I can't find it anywhere.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,868
1 Yorum
comment installer mydrive connect sur pc
pierre philippe caillet tarafından
