Ana içeriğe geç
Sony Xperia Z3 Compact, Eylül 2014'te piyasaya sürüldü.
Lower Loudspeaker doesn't work
Hi there, after the LCD replacement the lower loudspeaker seems not working anymore (also if replaced, so I think the problem is not the speaker itself but maybe is missing the connection between it and the MOBO). How is it connected to the MOBO? Maybe trough the black plastic bezel which contains the screws? It is broken in the left side, it fits good but maybe this is the problem that cause the malfunction?
Waiting 4 your kind reply
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Hi Maria
Did you solve the issue with lower speaker?
I have the same problem after replacing lcd
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
I will think the loudspeaker wasnt install correctly can you take a picture if you can.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
It is already installed in the replacements lcd I bought
tarafından
Yorum Ekle
Hello. I know that I write after a long time I just would like your help.
I have the same problem with the bottom sound, after replacing the battery, and while I did not cause any damage, it does not work at all at the bottom.
Have you solved this problem?
Puan 0
Yorum Ekle
Yanıtını ekle
Maria Aurora sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 1,299
