Ana içeriğe geç
TDK Trek Max, Bluetooth özelliklerine sahip kablosuz bir taşınabilir hoparlördür. Dahili mikrofon, Bluetooth ile hoparlöre bağlı olan veya kabloyla takılı olan tüm cihazlarda hoparlör üzerinden görüşme yapabilme imkanı tanır. Yardımcı giriş ve USB bağlantı noktaları, hoparlörü neredeyse tüm cihazlarla uyumlu hale getirir.
Why won't my speaker turn on?
I have had the device plugged in all day and it still won't turn on. My brother has the same speaker and uses my charger so I know that is not the problem. I'm thinking the battery is dead or maybe the charge port is malfunctioning. What can I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum
I saw you mentioned the sound was low on this speaker in another thread, did you get the power issue resolved then?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If the speaker is not turning on after a full charge it could be suffering from a battery malfunction. Follow our guide on battery replacement to fix this issue.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Trek max will work even without a battery connected. (power supply must be connected). I have one that works only when fully charged for a short time unless charger plugged in. This indicates a problem with battery voltage sensor. Same battery works fine in another unit. Your problem may be a worse case of this. I suggest Remove battery and test it.
Puan 0
1 Yorum:
My Trek Max A34 will not charge. I thought it was the battery so I boughf a new one. That won’t charge either. Only way Trek Max will work is plugged in. How do I fix this issue?
tarafından
Yorum Ekle
Jag får inget ljud i högtalarna
Puan 0
Yorum Ekle
Yanıtını ekle
Rebecca sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 4,313
