Ana içeriğe geç
The Keurig K75 Platinum Brewing System is a premium single cup home coffee brewing system by Keurig.
21 Soru Tümünü görüntüle
Doesn't fill to the right water level
My Keurig has the following issue: When I brew a cup it is not filling to the appropriate water level. (6 oz will only brew on the 8 oz setting) I've noticed that in the refill tank there is this rubbery thing and as coffee is brewing, water is leaking out of that back into the tank. Does this mean the water pump is broken and needs replaced or is it something else.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Mindy, that is actually a check valve. When the water tank outlet sits on it, it opens that check valve. You could another reservoir, or check the valve in the base. It is not your water pump since it does fill it up when you set it to 8oz.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mindy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 216
