You will need to check the vent actuator to see if its functioning. The actuator is a controller that opens and closes the flapper that direct the airflow from the fan . This is under the dash on the passenger side . There are two types of actuators , electric or vacuum . If its electric you may simply have a blown fuse or it could be a bad actuator, if its vacuum you would need to look for leaks in the system. which could be in the lines to the actuator or the actuator itself . Hope this helps
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
6
It's a 2008 Ford Escape.
S Thompson tarafından
I have the same issue on my 2008 Ford Escape.
joe tarafından
I have a 2014 Ford Taurus doing same thing
Chrishawn Green tarafından
I have the same problem on my 2009 Kia Sportage XL, please help!
luvssjcd tarafından
What if I replaced blem door and still doesn't work properly
Joe Minton tarafından
