Ana içeriğe geç
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
432 Soru Tümünü görüntüle
Is my logic board, or my power supply, or my RAM gone?
Hey guys,
My imac won't start up.
When I press the power button I can hear the hard drive and the fans working but no chime.
I've checked the RAM, by replacing.
When I took off the LCD to determine if the failure is related to a faulty LCD, I powered up the machine without the LCD connected. This resulted in blowing the fuse.
The diagnostic LEDs 1-3 are lit.
Has anybody a clue on that?
Mit freundlichen Grüßen
Andre.
Update (12/03/2015)
I replaced the ram by a certified one. That should be fine.
But still the same behavior.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
6 Yorum:
Remove the RAM and press the power button. Do you get beep error code?
tarafından
It sounds like it's getting power if you can hear the hard drive and fans power up.
tarafından
If you could try starting it without the RAM we can see what part of the POST it is failing. If you don't get a RAM error code we know it isn't even getting to that point. Which means the issue you're having is before the RAM check, which would lead me to believe that it is a processor or Power Supply issue since those are both checked before the RAM. If it's after then it could be an overdraw from the HDD or ODD
tarafından
Can you discern the desktop with a flashlight?
tarafından
since you heard the fan, it means its getting power, therefore the problem lies with either the display of the hard drive, check on those things and let me know how it goes so i can know how to help you
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
If you get no picture (black screen) the 3rd system LED is lit.
No sound (chime).
Fans kick on and second system LED is lit.
Then it is most likely your main board that has gone bad.
If it was the LCD, you would still get your chime.
If it was the HD you would still get a picture, usually to black and white pring of apple logo or a flashing folder with question mark.
Bad RAM you still would get a picture.
Bad power supply no LED's, fans or HD powering up.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
On this model the inverter fails a lot.
tarafından
Yorum Ekle
Yanıtını ekle
AndreGER sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 613
