Why is my battery bulky?
My battery got bulky after the phone got a bit overheated and I feel like its geting even bigger. Also the phone only works until like 50 percent of the battery is consumed, then it turns itself off.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If your phone battery has expanded in size, causing the battery not sit flat, it’s possible that your battery has bloated.
Although this bloating is an inbuilt mechanism to prevent pressure building up inside, they might be dangerous and i would recommend you proceed with caution. (this is not natural state for battery, so it should be changed)
In general, a swollen battery occurs when the battery’s cells are overcharged, as lithium-ion batteries “react unfavorably to overcharging,” according to Don Sadoway, Professor of Materials Chemistry at MIT. As Professor Sadoway explained to Electronics Weekly:
There are strict limits on how much current can be put through a lithium-ion cell. During normal charging, you never see metallic lithium, which is inherently unstable. But during overcharging, the lithium builds up faster than it can dissipate. The result is that metallic lithium plates up on the anode. At the same time, the cathode becomes an oxidizing agent and loses stability.
This reaction produces heat, which warms the gasses inside the battery, causing them to expand. Without any avenue for ventilation, the battery’s casing expands with the gasses, distorting and warping its appearance into that familiar swollen look.
Bu yanıt yardımcı oldu mu?
Just don't waste time searching how to repair the battery which is swollen just buy new one .don't try to use the same one as it can explode ...LCD and battery has no solution only solution is a replacement
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 8,110
