Why is my phone over heating? only using one app!
started happing after i used a cheap portable charger.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi there, You should stop using that cheap charger. It may have damaged your battery or some of the components on your motherboard. I say try get a brand new battery and see if that helps.
Bu yanıt yardımcı oldu mu?
Your battery and some of the components of your motherboard is damaged .
reason is the CHEAP CHARGER . cheap chargers make Voltage Swims in m.b components .
please replace your battery and try to use fabric samsung charger .
if it didn't work it means that your m.b is damaged and u must replace it :(
Arad_SB
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 67
