Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Phone says no sim card installed after screen replacement
EDIT: Now I've reset it, and I can't get in at all! It says "SIM required" on setup.
After replacing the screen on my iPhone 4 for the second time (The first repair didn't last long), the repair was relatively successful with (most) functions working properly. However, after booting up my phone, I find it does not recognize the SIM card. I have tried inserting the sim card from my sister's phone (which is identical) with no luck. It seems it is unable to read the sim card.
My best guess is that it is caused by some of my screws being missing. Some are missing from sending it to a repair shop where the phone was reassembled with missing screws and some screws just loose inside the phone.
My phone is missing several screws. It is on its third owner from my family, and has been broken a total of 3 times. The first time, we had it sent away to be fixed. Whoever did it did not do a careful job. When it broke under my ownership, I decided to fix it myself, to discover several screws loose inside the phone, as well as several screws missing. The only screw different from my last repair to this one AFAIK is the center display screw on the battery side.
Should I try this, or a factory reset? How is it best to proceed?
P.S.
I have a full set of iPhone 4 screws to be delivered to my house Thursday, but it is vastly preferable for me to have a functional phone during the weekdays.
Bu iyi bir soru mu?
Puan 0
1 Yorum
I've just reset, and now I can't get in without a sim card. Now I'm locked out of my phone completely!!!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Oh, gosh. Might have to put it into dfu and do a factory reset. If you're locked out. Which should be fine, as long as you have all your logins and passwords. As far as your sim. Try disconnecting reconnecting the battery, then using wifi. You could also try toggling the airplane mode. Resetting to factory settings. Try a friends SIM card. Try turning the phone off and then back on again. Update your wireless carrier. Update your iOS.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Of these, I've been using wifi, I've tried factory reset, my phones on the newest OS it supports, I've tried turning off + on, and I've tried a friends sim. I'll try the battery and airplane mode. Right now, it refuses to let me complete setup or connect it to iPhone because it thinks it has no sim.
tarafından
Yorum Ekle
Yanıtını ekle
Luke Taylor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 27
Her zaman: 5,725
