My phone isn't turning on and does not charge
my phone's run outta battery and when i was putting it to charge it fell
there wasnt any crack as such but it wont charge and is completely dead and won't turn on
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The charger port on the Galaxy S III can sometimes break , especially after extended use. In order to identify your problem, start small and work your way up.
First, try using a new (or at least different) charger cable for your phone, any android charger would do the trick.
If a new charger doesn't do the trick, test the battery. Take the back off of your phone by lifting under the indentation of the phone and then remove the battery completely.
If your phone turns on without the battery inside of it, then you just have a bad battery, which means you just need to buy a new one and replace it.
If not, your issue is most likely with the charger port of the phone on the motherboard itself. There is also a guide to replace your motherboard here, but this is a bit more advanced and requires some extra tools.
Kılavuz
Zorluk:
Kolay
2 - 5 minutes
Kılavuz
Zorluk:
Kolay
20 - 45 minutes
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 119
