Hi,
Have you checked the following
1. Touch the Home Key > Menu Key > System settings > Sound.
2. Touch Phone ringtone
3. Scroll through the ringtone list and select the ringtone you want to use.
4. Touch OK to save.
Also check the following
Adjusting Volumes
1. Touch the Home Key > Menu Key > System settings > Sound >
Volumes.
2. Adjust the volume for the ringtone volume
3. Touch OK to save.
Also check that you haven't enabled silent mode with vibrate
Silent mode, and touch Vibrate or Mute.
Hi belindaanderson16,
What you need to do now is prove whether you have a OS or software problem.
My suggestion is to do the following:
1. Ensure the phone's battery is fully charged.
2. Backup the phone using the backup feature.
3. Do a factory restore using the factory restore feature, - this will erase all your downloaded apps and user data and restore your phone to a factory default condition. Like it was when you first bought it.
If the ringtones still don't work after this, it is a OS problem. Check the warranty period of the phone and if still valid contact the manufacturer's customer service section regarding a warranty repair / replacement.
If it works then one of your downloaded apps may have caused the problem, When you restore your phone to what it was, using your backup, if it fails again it is one of the downloaded apps, if not it may have been a setting that wasn't restoring properly and has now cleared..
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
6
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
14 Yorum
I'm having the same issue uggggg i only had this phone 6 days
Sabrina Neeley tarafından
Me too 3days and I can't hear ring or dial tone when calling..Volume not great either
dmtripp37 tarafından
My sound is not working
On my ZTE
hooksdora101 tarafından
my phone has volume. cant hear when a call is coming in
lattymorrison tarafından
My phone doesn't ring or vibrate. Why
Mary Shannon tarafından
9 tane daha yorum göster
