Ana içeriğe geç
Aralık 2011'de piyasaya sürülen 10,1 inç tablet bilgisayar. Dört çekirdekli işlemci, Wi-Fi, GPS ve takılabilir klavye ile donatılmıştır.
Can't swipe tablet screen
can't swipe tablet screen. I have to use the mouse for everything.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Well I can only speak from my experience. For some reason if I unplug the charger after I turn it on my tab won't recognize touch. Also if I power it up with the keyboard attached then take it off the touch doesn't work either. If you've tried all this, try using the keyboard to power down then power it up unattached. If this doesn't work it may even just be dirty. Or it may need to be replaced.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi Bob,
I'm sorry about your touch screen not working. Fortunately, there are a couple of things you can do to fix it.
Restarting your device is always a good place to start, but considering this was posted 10 months ago I'm assuming that has been tried already. If the problem still persists, you can perform a soft reset by holding the power button for ten seconds, at which point your device will power down. When you turn it back on, it will have completed a soft reset, which is good for clearing minor software glitches and freezes (which may be why your screen wasn't responding).
If your screen's unresponsiveness is a hardware problem, where the touch-screen itself is actually broken, you can purchase a new screen and replace it in about 30-45 minutes or so. The web page for your device says that it is being developed and added to now, so you can expect that a guide for replacing the screen will be coming out some time in the next week or so. The guides are normally very comprehensive and easy to follow, with pictures included!
I hope this helps, and good luck replacing your screen if it is indeed broken!
Best,
Aaron
Puan 0
Yorum Ekle
Yanıtını ekle
bob suffron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 830
