I have a similar problem however it's a bit strange.
I have an iMac mid 2011 i5
For a period of time I had 2 ram X 2GB and 2 ram X 4GB a total of 12MB
Recently the slots of the 2 rams of 2GB appear empty.
Ok... I bought another 2X4GB to replace them and to upgrade the total memory in 16GB
I put the new couple but again only the 2 already installed chips regognised (the down couple- bank 0 and 1 in Dimm 1) The upper part (Bank 0 and 1 in Dimm 0 appear empty)
First thought were that the ports had an issue as described in the thread.
Of course I have checked all chips individually and all are ok.
The strange part is that the upper slots WORK normally and recognise the chips IF the down slots are empty.
If ALL slots have a chip inside, only the down couple of chips (Bank 0 and 1 in Dimm1) is recognised.
So, neither the chips have an issue nor the slots...individually.
I will appreciate any idea!
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum
There are 12 different A1278 models, let's nail yours down. What are the specs on your RAM chips? Are they identical? Do you have the original sticks?
mayer tarafından
I tried mentioned soultions like unscrewing screws of motherboard (3 pcs) and Memory banks (4 pcs), but to no avail! Then I found this solution on the Internet: https://juanomatic.net/2013/10/macbook-p...
Just an A4 folded and cut to approx 16 layers (=2 mm), clamped in between the two modules and then fastening the screws again did the job for me! YES!!!!
Frank van Herwaarden tarafından
