Why does my insignia flex 7 NOT charging?
i inserted my charger into the port, but it won't charge my tablet. I may have inserted the charger the wrong way, so it damaged the port. How do I replace it.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
sometimes if you do not use the original charger and cord then the device will not get enough amperage to charge. i have had this happen with many tablets. also sometimes it can be the charger part is messed up or lose and finally the battery could just be messed up. try a differ charger to see if that works and if you can try to replace the battery and see if that makes a difference. i hope this helps and good luck on your issue
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,183
