Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
What causes the power supply to get too hot?
A common thing we see is the power supply in the older model Playstation 3 systems get extremely hot and have to be replaced. One problem is the metal shielding they used and Sony fixed that in the newer models with a plastic casing but the power supplys are not universal.
For an old school electrican out there, what would cause the power supply to heat up that much? If a capacitor gets too hot, they usually pop and you can see the evidence of it so it has to be some other component causing the issue.
The only people that really do the repair on these are in China and the shipping costs get expensive :S
Bu iyi bir soru mu?
Puan 2
1 Yorum
+ Good question! I'd guess it's failing (but not yet failed) capacitors, but I'm not a power supply expert.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The biggest single cause I find for that kind of heat is resistance along the lines of current. A connection becomes slightly loose or a little corroded causing resistance to the flow of current. Resistance to current flow creates heat. Of course I can't say for certain that's the cause of your problem but it is a common source of heat in electrical and electronic systems.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
+ agreed
tarafından
Yorum Ekle
I would say it's the power regulation section. In taking apart some computer power supplies, I've seen power transistors and voltage regulators that were heavily heatsink'd. They are most likely the culprit, but it could also be a transformer, though at the power the PS3 operates, that's most likely not it.
Puan 0
Yorum Ekle
Same problem my ps3 ceche01 power supply gets hot I get error code 80010510 after updating a game on the ps3 (disc) so i launch the disc after updating and i get that code i looked it up and it seems that code is a internal power hardware failure ik how to try and fix but i hope it's nothing else causing that problem too occur
Puan 0
Yorum Ekle
Yanıtını ekle
WiredExtreme sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 9,118
