Ana içeriğe geç
Çift kameralı, 8 inç kapasitif çift çekirdekli Zeki Tablet. Bu cihazın model numarası TBQG884B'dir.
Device won't boot past "Android logo" splash screen
Presently, device will boot past the "Zeki" screen but will hang on the "Android" screen. We've let it sit for more than 60 minutes.
Attempted to do a factory reset.
Physical and online manuals do not address how to do this. Listed technical support has been unhelpful. Attempted at least twelve separate, recommended ways of doing a factory reset using the physical buttons (Pressing multiple combinations of the power button, vol + / vol - / both, and the reset button for varying lengths of time at different times during the reboot process). However, I'm certain I haven't tried every combination of buttons, press durations, and timings.
As a last-ditch effort I'm letting the battery run out in an attempt to make it forget everything, but I don't if that will accomplish anything (or how long that will take--days? weeks?).
Any advice on how to achieve a factory reset for this device, or otherwise restore functionality?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
Yorum Ekle
2 Cevap
Filtre ölçütü:
Try holding down the power button and the volume down button for five seconds and then releasing them. This should bring you to the fastboot menu where you can perform a factory reset, I would try this again.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
eso ya lo hice y nada. que hago entonces?
tarafından
Es posible que haya alguna manera corrompido los archivos de Android, si ese es el caso, no hay nada que pueda hacer por ti. (Estoy usando Google Translate, lo siento por la redacción raro.)
tarafından
Yorum Ekle
test combo: vol_+ & pwr_btn
Puan 0
Yorum Ekle
Yanıtını ekle
Chris Rutledge sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 2,833
