Ana içeriğe geç
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Soru Tümünü görüntüle
Error during restore now my Mac wont' read my iPod?
I bought a used ipod with the smiley face problem. I was thinking of upgrading to one of the 240gb drives to begin with but tttempted to do a restore by forcing it into Disk to see if I could get it to work in the meantine.
My Mac first read the iPod began to restore it but then it stopped midway and gave me an error message stating that it could not read the drive popularly.
Now, when I reconnect the iPod my Mac doesn't see it. I even tried resintalling iTunes as per the instructions in Apple's support system. Even if I force into disk mode again.
Any ideas? Is it the drive itseld? If I install a new drive will that do the trick?
Update
Anyone?
Update
Thanks for the answer! I don't find SMRT DAT.The options I had were: NTF, MEMORY, IO, POWER, ACCESSORIES TEST, SYSCFG, and RESET. IO was the right option and then there was a link for harddrive then HDSMARTData.
Here's what I found:
Retracts: 29
Reallocs: 1023
Pending Sectors: 0
PowerOn Hours: 200
Start/Stops: 6551
So I guess I have a bad hard drive? Can I upgrade this iPod to a 240gb kit without any other problems?
Thanks! I really appreciate the help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
After another attempt my Mac gave me an error message and gave me the option to initialize, ignore or eject. I clicked initialize and got the disk utility screen but do not know what to do here?
tarafından
Most likely it's asking you to format the HD.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
In order to tell if your hard drive is bad you can go to diagnostic mode. To do that press and hold the center button and the menu button for about 5 the ipod will reboot and then press the back and center button to enter diagnostic mode. Press menu and find SMRT DAT . When you are in the SMRT DAT(SMART DATA) menu you will see Retracts, Reallocs and Pending. The number of Reallocs and Pending should be Zero. If it is not zero you have a bad hard drive also on the Retracts typically any number is ok but if it is over 250 i would just make sure that the HDD still sounds good while spinning. Also if is comes up blank in the SMRT DAT it either need a new HDD cable or the cable reconnected. If it says not supported it is most likely a bad HDD. If you have any questions feel free to ask. I work for bestbuy as an ipod technician.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I am hoping someone can tell me if I can still upgrade this ipod and get it to work by inserting a new hard drive? I don't want to spend the money otherwise.
Thanks!
Puan 0
Yorum Ekle
Yanıtını ekle
Jean Marc Lavoie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,288
