Operating system won't load because only 395MB available disk space
The problem is easy top identify, fixing it however, not so much. Hence my post. Final Cut Pro likes to use up all my existing operating disk space (yellow other bar) in the background on my limited space SSD Operating System rather then use up the dedicated 750GB HDD i have specifically set aside for all my video editing work.
Back-story aside, when this happened in the past I simply pressed and held ALT while simultaneously turning my Mac on and then simply selected the reboot disk drive symbol on the white backdrop and then proceeded to clear FCPro X caches where necessary in order to get my yellow bar of disk space back, so I can then start and/or finish existing projects.
Unfortunately, the MAC is not allowing me this option any-more for some reason. It simply restarts the same Dos Mode with 'unable to load' in that cream coloured text offset by that old school black DOS MODE backdrop.
Finally I am currently typing this post from my Windows partition thankfully but I still have No clue how to fix this, anybody experience this or am I the only one?
Bu iyi bir soru mu?
2 Yorum
First it would help to know exactly which machine you have. Next what SSD are you running as the primary boot drive and how big is it? How much space does the windows partition take and how often is it used? What operating systems are you running? How much RAM do you have?
mayer tarafından
Can I actually fix and upgrade my post G5 (2007) Mac Pro?
First i would like to say thank you for your response. The full specifications are above and further answers to your questions are below:
1.) Functioning Ram is currently between 16 and 22 GB, hard to tell performance and hardware wise exactly. The stock RAM is pretty beat up by the looks of things & final cut seems to run better on my 16gb macbook. Anyway before the crash 22GB was shown on the about this mac tab.
2.) The OS was 10.6, the maximum OS I am told it xan run is 10.7 apparently?
3.) Primary SSD was a 75-25% split on the sandisk 128GB, rookie mistake I now am aware of thankfully.
I think that covers all the bases?
brookchristian tarafından
