Ana içeriğe geç
Kasım 2006'da Kuzey Amerika'da piyasaya sürülen Wii, hem çevrimiçi oyunları hem de Wii Shop Channel üzerinden oyunların ve medya uygulamalarının dijital dağıtımını destekleyerek internet bağlantısını doğrudan destekleyen ilk Nintendo ev konsoludur.
How do you fix a button that won't press?
The Wii took a tumble a while back, and since then, the eject button doesn't click anymore. Unless its positioned just right, it'll forever try to eject. How do you fix/replace an eject button?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If I'm hearing you right, the console is constantly trying to eject the disc while the button is not being pressed. A solution you may want to consider is removing the button entirely (I'm pretty sure you can still eject the disc from the Wii menu). Try removing the faceplate to get to the button and remove it, to see if that fixes the problem or at the very least to clean out any broken plastic components that may still be in there. Wii Faceplate
Here's the part: Nintendo Wii Faceplate
EDIT: Whoops! Turns out you can't eject the disc from the Wii Menu. I tried through a whole episode of Seinfeld.
Replace the faceplate and its buttons. Görseli
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
iFixit now has the part you need to repair your Wii (instructions linked to in BWest's answer)
Ürün
$19.99
Puan 3
Yorum Ekle
the eject button can be replaced but its very small. I use a digital microscope to clearly see the solder points.
Puan 1
Yorum Ekle
clean the buttons some times got dust around
Puan 0
Yorum Ekle
Yes and i need you to fix it
Puan 0
Yorum Ekle
I took apart the Wii and found the disc holder and pushed the egect button a couple times then put it back together and the your set
Puan 0
Yorum Ekle
Yanıtını ekle
Kevin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 20,177
