Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
542 Soru Tümünü görüntüle
imac not starting up even in safe boot mode...the apple hardware test
results were error code
1st pass 4MOT/1/40000003:HDD1404
2nd pass 4MOT/1/40000003:HDD1409
Please help.We purchased the computer in Singapore and it was working fine until after we shipped it over to Toronto where we are now.Appreciate any help.
Thank you so much.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
I know it's old but others may find it useful.
I believe the error relates to the HDD fan not spinning up to the required speed
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
why?
tarafından
Yorum Ekle
En Yararlı Yanıt
I concur - those AHT codes refer to the Hard Drive/Hard Drive controller. It could be as simple as the connector working loose in transit.
If you are near an Apple Store or AASP, take it in and have them run Apple Service Diagnostics - it is more comprehensive and should help pinpoint the failed subsystem. (ASD is not available to the public.)
Puan 1
2 Comments:
correction: not available "legally" to the public.
tarafından
For Canada you can find a store via this link that may also repair: http://www.apple.com/ca/buy/locator/
tarafından
Yorum Ekle
Looks like you need a new hard drive get one here. If you need to recover data I suggest Data Rescue 3, it actually works, I've used it to recover data myself.
Puan 0
2 Comments:
Careful with data recovery software on a failing drive. It can make the problem of getting the data more difficult and costly if it doesn't work. These programs put the drive through vigorous use. Like taking your grandma for a marathon run...
tarafından
Not really actually, it's not that expensive and you usually only need to run it once. Obviously it's not gonna be good if you do it 30 times, but you only need to do it once or twice. That is why trying to clone the drive first is good.
tarafından
Yorum Ekle
'cause that's what the service manual tells me... there is no reference to the following number but I believe it is the actual speed detected at time of error.
Puan 0
Yorum Ekle
Yanıtını ekle
obstructivism sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,859
