Ana içeriğe geç
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
184 Soru Tümünü görüntüle
iPad 2 cycles between "searching" and "no service"
iPad 2 3G, cycles between "Searching..." and "No Service"
Things I have tried:
  • Swapped sim card
  • Replaced Sim tray and headphone jack flex
  • Replaced 3G antenna
I want to avoid doing a restore if I can, unless I am given advice that suggests it is the only option. I am not willing to 'just try it,' as most of the time undocumented issues like this are not fixed by restoring the device.
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Dizüstü Bilgisayar Bataryaları
An easy fix for a big power boost.
Hemen Alışveriş Yapın
1 Cevap
Filtre ölçütü:
Does it display an imei number under Settings > About Device (Not exactly sure what it's called). If no, the baseband IC chip is most likely damaged.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
Hi, thanks for the reply. It shows the IMEI number without any issues, which is fortunate in that sense.
tarafından
Yorum Ekle
Yanıtını ekle
Calvin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 452
