Why can't I hear when I plug in headphones?
Why can't I hear any music when I plug my headphones in?
Bu iyi bir soru mu?
High-end Fire OS 5 tablet released by Amazon in 2015. Features a 10.1" HD display and MediaTek quad-core processor.
Make sure the headphones being used are completely plugged in. The headphones being partially plugged in can cause low sound quality or no sound at all. If you are still not hearing any audio after checking the plug, try using the headphones on another device. If the same issue persists, try using a different set of headphones as they might be faulty. If audio issues continue with functional headphones and they are plugged in fully, then it is possible the headphone jack might be faulty. In this case, the headphone jack probably needs to be replaced. Amazon Fire HD 10 Troubleshooting Guide
Yorumlar:
it's not working i still can't here nothing this stuff doesn't even work
Makayla quest tarafından
its not working
Yorumlar:
Once I use the head phone plug thru my receiver on my tv no problem once I plug fire stick I don’t get any voice
Giuseppe Dalessio tarafından
Lick the head of the plug in and insert, for some reason the contacts are connecting very well. That did the trick.
Son 24 Saat: 19
Son 7 gün: 113
Son 30 gün: 620
Her zaman: 28,312
check if its muted, unplug your headphones and see if there is even sound coming out of the device/
Spoofo9t9 tarafından
The sound comes out of the speaker when i play it but when i plug my earphones on i dont hear anything
Fayeza Raheem tarafından
I had same problems as yours@Fayeza Raheem..I don't know why...I can't hear anything when I plugged in my wired headphone..when I unplugged it..I can hear the sound came from speaker
Silmina Zahra tarafından
I would try using a soft bristled toothbrush to clean out the 3.5mm headphone jack. I'm assuming you've tried a different set of headphones...
TYLER GOODWIN tarafından
