Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
80 Soru Tümünü görüntüle
grey screen on mac os 9.1 startup (Gsod)
the first time, my Ibook turns on, but the second time it showed a grey screen on mac os 9.1, should i get a new display or reinstall os? help me
ps: i have a model m2453 and color's blueberry
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Pre-Installed MacOS: 8.6* Maximum MacOS: X 10.3.9
See if it will start up from either a retail 9.1 or the original system installation optical disk, by inserting the disk on start up and holding down the "C" key. If it boots OK, then you know it is a software or hard drive issue. You can then Run Disk Utilities to try to repair or reformat the drive (use the write zero option to map out any bad blocks). Then reinstall a system.
This was the original iBook:
Apple iBook G3/366 SE (Original/Clamshell) Specs
Identifiers: Original/Clamshell - M7716LL/A - PowerBook2,1 - M2453 - N/Aissue.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
thanks mayer! hope that helps
tarafından
Yorum Ekle
Yanıtını ekle
Wokipoki sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 363
