Water or coffee is not dispensing
When I hit the brew button I notice that no coffee pours into the cup. If it does it comes out very slowly.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The water overflows instead of passing through the machine and dispensing coffee:
If the water or coffee overflows around the K-cup holder instead of dispensing, then your needles may not be penetrating the K-cup or the K-cup holder may be clogged. You can view our guide [here] on how to replace the top needle.
The water never makes its path to the K-cup:
If the water poured into the reservoir does not drain, it will not reach the K-cup. The drain on the Keurig may be clogged.
Bu yanıt yardımcı oldu mu?
On my K10 the coffee was not coming out. After attempting to disassemble the Keurig (thanks to Roberto Maldonado for his guide) I discovered coffee grounds in the hose from the water pump, just above the needle for piercing the top of the K-cup. Long story made short, I never needed to disassemble the K10. I believe the problem was that my wife had purchased coffee pods that were not made of plastic. They had a paper top then a bundle of tightly packed coffee beneath. When these were pierced, they forced coffee into the top needle where it eventually clogged. The solution was to bend a paperclip and push it into the top needle to clear the clog.
BTW, my K10 is now 7 years old and is working perfectly.
Son 24 Saat: 7
Son 7 gün: 43
Son 30 gün: 197
Her zaman: 4,902
1 Yorum
I have tried most all troubleshooting methods... still takes forever to come down or only fills halfway
debbie palumbo tarafından
