Hi,
Have you checked, if there is enough time to do so, what the state of charge of the battery is? Have you tried charging it to fully charged-100% . (do this with the tablet switched off so that it won't take so long to do) and then seeing how it performs.
If you have done the above and you still have problems, try connecting the charger (switched on) to your tablet and see if the tablet remains on when you use it. If it does then your battery is probably failing and it needs to be replaced.
Even rechargeable batteries have a life span.
Hi,
Try the following and see if this resolves the problem. This is not a master reset so your information will not be deleted.
1. If your device is on, turn it off.
2. Press & hold the Volume down button. While holding Volume down, press & hold the Power button until the device turns on. You'll see the word "Start" with an arrow around it .
3. Press the Volume down button until you highlight "Recovery mode."
4. Press the Power button to start recovery mode. You'll see an image of an Android robot with a red exclamation mark.
5. Press & hold the Power button. While holding Power, press the Volume up button once. Then release Power.
6. Press the Volume down button until you highlight "Wipe cache partition," and then press the Power button to select it.
7. Press the Volume down button until you highlight “Yes,” and then press the Power button to select it.
8. Wait until the cache is wiped. You’ll see the words, “Cache wipe complete.”
9. Press the Power button to restart your device.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
9
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
12 Yorum
Ok I tried all the fixes short of having it professionaly repaired. I deleted all apps, finally it ahut down as soon as I turned it on. After trying many times i was able to turn it off manually. I then charged it while off .at first it didnt seem ti help but after a few time the shut downs became less frequent and now its running fine. I continue to close everything and shut it down before charging it to 100%.
Marjorie Knott tarafından
Find a table with one leg about 1/2 inch shorter than the others. Place device under short leg. Leave it there and forget about it.
Geoff tarafından
That might honestly be a better use for it at this point.
Jenna Pierce tarafından
Oh that's funny. I have had computers and a few other things that were impossible to fix and I have used them as table legs, saw horses - - - Etc
sam marasco tarafından
My table keeps cutting off even when it's fully charge what can the problem be
sweeterthancandy46 tarafından
7 tane daha yorum göster
