Ana içeriğe geç
The Black and Decker is a cordless household drill that can be found by the serial no. LDX 120C
Why isn't the chuck able to tighten?
When i turn the head of the drill to loosen the head nothing is moving, what do i do?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The problem you are facing is because of the planet gear inside the chuck. the gear might be loose, or some the components may be broken and need to be replaced.
Follow our guide (haven't completed the guide yet) that provides a step by step process on how to do so.
Check out our Troubleshooting
for more help.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
My drill had the screw that holds the chuck to the shaft come loose, and it bound up inside so the chuck wouldn't turn. I took it out, and it worked fine after that. The chuck hasn't fallen out either, must be glued on.
Puan 1
Yorum Ekle
Yanıtını ekle
jeffrey zakka sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 6,453
