32 bit to a 64 bit compatible
how i can know if my laptop is compatible to a bit 64.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hold the windows key and pause break down together . This will open your System and if you look under system type it will tell you if your running 32-bit or 64-bit. If you cant open you system this way go to the start menu open the control panel then find system . Hope this helps
Bu yanıt yardımcı oldu mu?
If it is running windows; go to control panel>system. Under the line "system" it will say system type: 64-bit or 32-bit operating system depending on which it is.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 5,383
