Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
1182 Soru Tümünü görüntüle
All USB ports not working for no reason
So i have a Toshiba laptop that i use regulary, and while i was using it a couple of days ago the mouse just stopped working. I started trying different things in the USB Ports, and none of them work, so i know it cant have just been that mouse. I hadnt pressed an odd key or anything since every key ive tried has done nothing to fix it. ive looked at tutorials all over youtube and none of them have worked. even taking the battery out doesnt work. Help? ☹
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
You Need to upgrade your usb drivers.
go on toshiba website and update them.
that should solve the issue
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
check under you laptop there should be a sticker saying model number.
https://www.toshiba.eu/innovation/downlo...
tarafından
@blanco Every time I type all the things in it just says that they cant seem to find matching info. ive looked under my pc and it doesn't say anywhere what model number it is.
tarafından
It doesn't say what series either.
tarafından
@blanco nevermind, done it. Thanks so much for your help! :)
tarafından
no problem. :) glad you have solved it
tarafından
Yorum Ekle
start by login bios check if the usb are disabled then try to do resotre your windows to date that work fine
if nothing happen you must pull out the motherboard and do the voltage test
Puan 0
Yorum Ekle
Yanıtını ekle
no. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 96
