Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
iPhone 5c Microphone doesn't work
A little while ago the microphone on my iPhone stopped working. There must be two mics, because phone calls work, but calls on speaker phone, Siri, etc don't work.
I'm going to be replacing my screen anyways, so I thought it might be a good opportunity to replace the microphone. But I can't find parts or a guide for such on here. Is it included in another set of parts or something? What can I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
That mic is located on the front facing camera cable. It's pretty easy to change that cable as part of the screen replacement.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Rich is correct. most likely needs replaced but the earpiece mesh can get also fairly blocked up which also includes a hole for that mic. if you remove the screen and that part then take a look at behind it, hold screen up to the light and you should see light pass through it. if not then scrape the mesh from the inside and outside with a fine pin etc to allow more sound to pass through.
Puan 1
Yorum Ekle
Yanıtını ekle
Evan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 266
