Why does my screen go dark so quickly?
My tablet screen goes blank after a few seconds, why does it do that and how do I change it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The screen will often go dark from inactivity but you can also adjust the brightness settings according to your preference.
Bu yanıt yardımcı oldu mu?
The screen may go dark faster than desired if the device is in a power save mode. Check the device settings to see if this is the case. If this does not help, check the device settings to see if it allows the user to select the amount of time that can pass before the screen goes dim/dark.
How do you change the amount of time it takes before the screen goes darkness
I wish I knew!
Hi there! I don't know if this still helps, but maybe check your settings, and search for power settings in the settings search tab. You might get the screen time preference under that.
Instead of I phone users offering advice, why doesn’t APPLE provide a solution?
A “score”?! I need an answer, this isn’t a game.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 6,109
