Ana içeriğe geç
Repair information and guides for MacBook Pro models with 13" displays.
9729 Soru Tümünü görüntüle
Upgrade battery on 13' MacBook Pro
I have the mid-2009 13" macbook pro with core2 and A1322 battery. Mine is losing it's charge capacity and I want to get the newer batteries, so what fits and what are the part numbers? Can I get the newest 63.5wh battery or even the 10 hour battery?
Bu iyi bir soru mu?
Puan 2
1 Yorum
Same situation but posting this at 2018. Except the battery does not hold a charge, only works when using a charger.
Any help would be greatly received.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here is the link to an upgrade battery that iFixit sells.
[bağlı ürün eksik veya kapalı: IF163-003]
And here is a link to another source--in both cases talk to the supplier and make sure it fits your computer.
http://eshop.macsales.com/item/Newer%20T...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
The battery from the Mid-2009 version is labeled A1322 and has the APN 661-5229. It is 10.95 V and 60 Wh.
The battery from the Mid-2010 version is ALSO labeled A1322 and has the APN 661-5557. It is 10.95 V and is bumped up to 63.5 Wh. It is fully compatible with your machine.
As for iFixit's parts, these particular batteries are pulled directly from new or refurbished Apple machines. We mark them "used" because they came from a machine that was turned on for testing (much like a new car becomes a used car the second it is driven off the car lot). The mAh rating is represented on the part page as a range rather than a specific number, because these batteries, direct from Apple's machines, have a sizable variation in actual mAh from battery to battery.
Puan 2
Yorum Ekle
That's a used battery from ifixit?
And they do not give any mAh or Wh at all?
Just that it is fully tested? And that for $119.5?
I have to admit: I do have little confidence here.
What are the real specs of an original A1322? Apple says 63.5 Wh. This would be 10.8 V and 5880 mAh.
Or 5770 mA and 11.0 V.
I do see many third party offers, naming about 60 Wh, 10.95 V, ergo 5480 mAh.
Steve J. claimed superior quality for their current, not user-replaceable batteries (does not apply for ifixit-readers). Are those 3rd party replacements a real match?
Puan 0
Yorum Ekle
3rd party replacements you can see here:
http://www.laptopbatterybuy.com/apple-a1...
Puan 0
2 Yorum:
bad link....
tarafından
Bad link also.
tarafından
Yorum Ekle
Ugh none of these answers help.
Trying to find a battery for my mid 2010 MacBook pro. It's completely failing even on a charger.
Puan 0
1 Yorum:
you need the microscopic model number off the bottom of the laptop to get the right part to order.
tarafından
Yorum Ekle
Yanıtını ekle
Alex Fallas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 27,767
