Ana içeriğe geç
HTC One (kod adı M7), HTC'nin 2013 yılı amiral gemisi telefonudur. Kusursuz tasarlanmış yekpare alüminyum gövdeye, ön tarafta 2 adet büyük hoparlöre ve 4.7 inç 1080p ekrana sahiptir.
149 Soru Tümünü görüntüle
HTC One battery dead with no warning
Hi!
My HTC One 32g is 8 months old, and now shuts down down due to dead battery with no warning.
Its happening at 30 - 60% charge, with no indication the battery is about to run out. Is this a battery issue or a bigger problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
It could be numeorus things that could be causing your battery to drain much faster from programs and apps running in the background. Charging your phone and never powering it down while it's charging. Click on the link below for tips to extend and isolate a defective battery. If you do all the steps and phone still dies quick then yes it's the battery that needs to be replaced.
http://www.htc.com/us/support/htc-one-m8...
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
The battery dies already above 50%. Pretty sure the battery is faulty and needs to be replaced
To OP: Don't use cheap car chargers, bad quality chargers or cables. They can cause this issue in the long run.
tarafından
Yorum Ekle
This can help you
http://pcexperts.pl/blog/zalany-telefon-...
Puan 0
Yorum Ekle
Yanıtını ekle
Jess Urquhart sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 4,504
