Ana içeriğe geç
16:9 LCD monitor with a 1600x900 resolution display.
4 Soru Tümünü görüntüle
I can barely see the screen
I can barely see the screen and adjusting it makes no difference
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
shawn sounds like your backlight has failed. Most common cause for that are bad capacitors. Your monitor does not have a separate inverter but it is part of the power board. Start by disassembling the monitor and take a look at the boards and the caps. Check for bulging or leaking caps. Post some good images of your boards with your original question. For that use this guide. Since I only have the assembly instructions, substitute the assemble with disassemble
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I went ahead and tore it apart right after posting the question and not one of the caps had much for capacitance,they was toast.
tarafından
Did you replace those?
tarafından
Yorum Ekle
Yanıtını ekle
shawn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 300
