Laptop will not charge, does not recognize power cable
So I bought an Asus ROG G751JT 8 months ago, and it's been fine up until last month, when it stopped charging plugged into the power cord (The green battery charging light does not come on). Didn't use it for a few days thinking it was bricked and would have to be sent in for repairs, but then one day it magically decided to charge again.
Everything's been good and fine up until last night, when while I was using it (stationary, on a table) the brightness of my screen changed a few times, indicating the laptop switching back and forth from AC to battery power, and it is now back to not charging at all. Is the laptops power adaptor connection to blame? The cable fits snugly, but perhaps not as snugly as I would like (there is a little give to it when wiggled side to side).
Really sort of bummed out that my first $1,500 foray back into Windows as resulted in a bricked computer in under a year, when my Mac has been chugging along for over 6. Any help would be really appreciated. :(
Bu iyi bir soru mu?
7 Yorum
Had this issue since day one. My GL702VT is not usable unless it's plugged into the mains. Total waste of space
sittin_kitty tarafından
I have the same laptop and am having literally the exact same issue, I had it 8 months in and sent it back to get it fixed when it was under warranty, but after that another 8 months went by, the warranty went up and now it's doing it again. Does any one else know if this is a common issue and if so can we get some people together and go to Asus about it?
zeack1 tarafından
It's happening to me as well. 2nd time it's happened over the span of a couple months. Asus quoted me $1300 to fix the &&^&^$^ thing. If you're having trouble still, email me so we can get something done about this. Marcuscabeceira@gmail.com
Marcus Cabeceira tarafından
I have a G751J, I was having the same problem only my laptop would shut off randomly. I took it apart and found that the fans were not running, from research I have done the battery can go bad in these laptops due to overheating and since the batteries are not meant to be replaced in this laptop you would need to take it somewhere to get it fixed. But I am still in the process of getting mine fixed so once I have more info on what went wrong I will come back and share
Samantha Lynn tarafından
I've been the merry owner of a G751 JY for 3 years. It's been a few weeks though since I have started experiencing a similar problem. Computer past warranty.
Pc would stop charging when playing a game, for most games, even $@$*!& ones.
Often it would start charging again after shutting down the game, but sometimes I was just f***ed and I would have to try and find solutions online as my battery was going empty pretty fast (hey its a rog)
Got it to a repair store so that they could tell me if battery/adapter/connector was at fault. Ended up bummed 90dollars for a new ac block that in the end did not fix it. Pc worked normally for a few days after being back from the store though.
Knowing asus's kinda prices for repair, i disassembled it, tried to make it work without battery, same problem except it would shut down instead of stopping the charge.
I proceeded to fully unscrew/unplug everything and put it all back up, and it worked, until I transported it to another place.
Martin tarafından
2 tane daha yorum göster
