Ana içeriğe geç
Canon EOS 40D, Ağustos 2007'de piyasaya sürülen 10,1 MP çözünürlüğünde dijital tek lensli refleks (DSLR) fotoğraf makinesidir.
My camera won't fire.
My Canon 40D will not fire from the main body, it will only fire from a battery grip. I have tried various lenses and also with the battery grip removed. The main body will not fire, it just makes a bleeping noise as if its about to fire. I have set it back to factory settings but still no joy.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
This is a more or less common issue with the 40D (and as far as I know 30D and 50D as well, because same shutter button unit).
The shutter button is most likely not working because of some kind of dirt in it. There are two possible solutions I know of. Both aim at the goal of cleaning the button with use of cleaning fluid suitable for electronics.
1st: Complicated but "safe", dissasmble and clean the button part by hand.
- you should be able to follow this instruction to get to the button unit: Canon EOS 40D Deklanşör Düğmesi Değişimi
(The instruction is not from me)
- clean the shutter
-- a) either by disassembling it completely and clean every single part of it
-- b) or by just soaking the button unit in cleaning fluid and pressing it several times
- let it dry and take it back together
2nd: Quick'n'Dirty but maybe "unsafe", dont disassamble, just pour the cleaning fluid into the battery compartment
- remove both batteries from the camera (the main battery as well as the little time-save-one
- prepare a towel or something onto your bench
- rest the camera so on the towel, that the shutter is on the lowest point
- pour cleaning flouid in, it should flow directly through the shutter button to the outside of the camera
- it should NOT flow through the top lcd (don't know if really a problem or not)
- press shutter several times
- let rest and dry
I personally tried version 1a) and it worked. But over time the shutter button got worse again and I would have had to do it again.
As cleaning fluid I used 100% Isopropanol ( engl. Isopropyl alcohol ?), which was available at a local DIY-electronics shop (Conrad, in Germany).
Good Luck! :)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Nick Brunsdon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 916
