Ana içeriğe geç
Beats Pill'in ikinci sürümü. California'da Apple tarafından satılmıştır. 2013 yılında piyasaya sürülmüştür. Model numarası: BO513.
Why won't my pill charge?
All of a sudden my pill won't charge,I didn't drop it nor is it damaged.Can you help?
Bu iyi bir soru mu?
Puan 3
1 Yorum
The battery has 4cables in a block connected to the circuit board pull this block out of the circuit board then reconnect. I'm pretty sure mine had just vibrated loose,beats pill worked straight away and taking a charge.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's how to get into it. Look for the number on the battery:
https://www.youtube.com/watch?v=Jh3VWvA3...
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
I have met the same problem, my beats pill 2.0 won‘t charge and out of warranty. After watching this video, i bought a replacement battery from amazon and replaced it by myself, it works great. Thank you. The battery's ASIN is B01MXDCSXT, you can search it on Amazon.
tarafından
Yorum Ekle
most likely, the battery has gone bad.
i am searching for one myself, but its starting to seem that you have to send it back to apple for battery repair\replace..
Update (12/04/2019)
just to add a bit.. you will also need to be comfortable soldering and unsoldering the battery leads.
if you can do that, should be a fun project.
Puan 3
5 Yorum:
after some digging, i found that the pill takes 2 batteries and are almost the exact same size as a gopro hero 2 battery. you have to take the cover off the gopro battery to get it to fit, but it will work.
you do need to be comfortable with taking apart small parts and possibly modifying the case a tiny tiny bit to get it to fit, but it does work..
tarafından
Does it Cost money if you send it back for a battery replacement
tarafından
Send it and let us know if they do it for free...
tarafından
Only if it is out of warranty
tarafından
How much does it costs if it's out of warranty?
tarafından
Yorum Ekle
Yanıtını ekle
Joe Wright sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 34
Her zaman: 40,586
