Ana içeriğe geç
RCA 10 Viking Pro için cihaz ve onarım kılavuzları. Bu Android tablet, ayrılabilir klavyeye sahiptir ve RCT6303W87 DK model numarasıyla tanımlanabilir.
Screen can't use it
My touch screen I can't do anything with it????it just gos nuts
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
4 Cevap
Filtre ölçütü:
Hello Marvin
It sounds like your digitiser might be faulty.
You can buy a new one from here.
You can see a screen tear down from here.
Hope this helps.
David
My Computer Dude
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Have you tried resetting your device? What about performing a firmware update? If problem still persists, open up the casing and check the ribbon cables. Make sure they are tight and snug (make sure your device is powered off while performing this step; will void your warranty). If the problem continues to occur, most likely your touch screen digitizer is faulty. It is relatively easy and inexpensive to replace (replacement panels start at around $8 on eBay or any other retailer). When buying a new panel, ensure that model and version number matches yours. Hopefully this helps.
Puan 0
Yorum Ekle
  • Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
Puan 0
Yorum Ekle
My screen won’t work and I can’t get in
Puan 0
1 Yorum:
And it’s cracked
tarafından
Yorum Ekle
Yanıtını ekle
Marvin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,263
